[GRASS5] Debian and d.m/d.zoom bug - /etc/ld.so.conf
Paul Kelly paul-grass at stjohnspoint.co.uk
Wed Dec 1 08:31:16 EST 2004
On Wed, 1 Dec 2004, Markus Neteler wrote:
>>> d.m is now updated in CVS.
>>> Debian users: please try again (don't forget to revert the /etc/ld.so.conf
>>> change
>>> for testing, run ldconfig as well).
>>> I had to modify lib/init/grass-run.sh to make it working for Fedora:
>>> LD_LIBRARY_PATH=$LD_LIBRARY_PATH:"$GISBASE/lib"
>>>                ^^^^^^^^^^^^^^^^^-added
>>> Hopefully this problem is resolved now.
>> Well in general it looks like it should just be passing on the current
>> LD_LIBRARY_PATH (whatever that contains). Would something like
>> exec xterm -e LD_LIBRARY_PATH=$env(LD_LIBRARY_PATH) d.zoom
>> (in the Tcl code) not work?
>> And there is also the problem (noted in Glynn's original e-mail) that e.g.
>> LD_LIBRARY_PATH is called different things on different platforms, e.g.
>> DYLD_LIBRARY_PATH on OS X. But this can be fixed by dynamically
>> substituting the correct variable name in at compile-time like is done for
>> lib/init/init.sh
>> Paul
> [isn't it easier to handle such necessary conditions in grass-run.sh
> rather than messing up d.m.tcl? ]
The thing is we are assuming LD_LIBRARY_PATH has been unset by the time
grass-run.sh is run, and we need to set it again. So your change doesn't
really make sense as on the systems that have the problem,
$LD_LIBRARY_PATH will already be empty by that stage. I was thinking if we
need to pass on an already existing LD_LIBRARY_PATH, it needs to be
evaluated before xterm is run as that is what unsets it.
I'm not sure enough to make a change, just want to add to the discussion
and have it documented!
Paul
