[GRASS5] [bug #2748] (grass) Cannot display vector data
Request Tracker grass-bugs at intevation.de
Wed Dec 1 10:21:57 EST 2004
this bug's URL: http://intevation.de/rt/webrt?serial_num=2748
Subject: Cannot display vector data
Platform: other
grass obtained from: Trento Italy site
grass binary for platform: Compiled from Sources
I compiled grass5.4 under fedora core3(x86_64) by following settings.
../grass-5.4.0/configure --with-glx --with-proj --with-motif --with-cxx --with-blas --with-lapack --with-freetype --with-freetype-includes=/usr/include/freetype2 --with-lapack --with-gdal=/usr/local/bin/gdal-config --with-nls --with-odbc --enable-64bit
In other system(fedora core3(i386)), I created the raster and vector (area) data, and then copied this database to fedora core3(x86_64) system.
The raster data is no problem, but vector data could not display using d.vect.area command. This command output the following message:
Warning: Long   is size 8
Data file has been modified.  You MUST first run 'v.support'
In other system(fedora core3(i386)), I could correctly display same vector data using d.vect.area.
-------------------------------------------- Managed by Request Tracker
