[GRASS5] [bug #2742] (grass) file names cut off on snapshot web page
Markus Neteler
neteler at itc.it
Wed Dec 1 11:37:58 EST 2004
On Wed, Dec 01, 2004 at 10:18:33AM +0000, Glynn Clements wrote:
> guest user via RT wrote:
> > Does anyone know who to change the Apache configuration to
> > show more in the list?
> http://httpd.apache.org/docs/mod/mod_autoindex.html#indexoptions
> says:
> IndexOptions directive
> Syntax: IndexOptions option [option] ... (Apache 1.3.2 and earlier)
> Syntax: IndexOptions [+|-]option [[+|-]option] ... (Apache 1.3.3 and later)
> NameWidth=[n | *] (Apache 1.3.2 and later)
> The NameWidth keyword allows you to specify the width of the filename column in bytes. If the keyword value is '*', then the column is automatically sized to the length of the longest filename in the display.
> The above is for 1.3, but the same appears to apply to 2.0:
> http://httpd.apache.org/docs-2.0/mod/mod_autoindex.html#indexoptions
Thanks, resolved:
http://grass.itc.it/grass57/binary/linux/snapshot/
Markus
