[GRASS5] v.out.ascii: Segmentation fault
Hamish
hamish_nospam at yahoo.com
Wed Dec 1 18:53:37 EST 2004
> > It's primarily an issue for tcltkgrass and d.m, as running
> > "xterm -e <command>" (i.e. the "term" procedure) will result in the
> > command being run with LD_LIBRARY_PATH unset.
> I would like just to note, that I use aterm
Is a $GRASS_TERM enviro (shell) variable called for? this doesn't really
address the problem but would make patching easier in this case and some
people passionately care about such things .. Gets away from hard coded
xterm, but I guess you can't guarantee e.g. "-e" works as expected..
Hamish
