[GRASS5] [bug #2761] (grass) d.path documentation should mention how it gets the from and to points
Request Tracker
grass-bugs at intevation.de
Thu Dec 2 23:07:34 EST 2004
this bug's URL: http://intevation.de/rt/webrt?serial_num=2761
d.path documentation should mention that it uses the mouse to get the
from and to points. One is left wondering until he actually tries the
command out.
The SEE ALSO should mention other batch-job non-display ways of
getting the shortest/longest path.
--- Headers Follow ---
>From jidanni at jidanni.org Fri Dec 3 05:07:34 2004
Return-Path: <jidanni at jidanni.org>
Delivered-To: grass-bugs at lists.intevation.de
Received: from mail.intevation.de (aktaia [212.95.126.10])
by lists.intevation.de (Postfix) with ESMTP id 775E6102BC0
for <grass-bugs at lists.intevation.de>; Fri, 3 Dec 2004 05:07:34 +0100 (CET)
Received: from localhost (localhost [127.0.0.1])
by mail.intevation.de (Postfix) with ESMTP id 3CCF93711B
Received: from frodo.hserus.net (frodo.hserus.net [204.74.68.40])
by mail.intevation.de (Postfix) with ESMTP id C8C1236F13
for <grass-bugs at intevation.de>; Fri, 3 Dec 2004 05:07:32 +0100 (CET)
Received: from [219.69.72.5] (port=33578 helo=jidanni1)
by frodo.hserus.net with esmtpsa
(Cipher TLSv1:RC4-SHA:128) (Exim 4.43 #0)
id 1Ca4jD-0000Nf-6h by authid <jidanni> with plain
for <grass-bugs at intevation.de>; Fri, 03 Dec 2004 09:37:31 +0530
To: grass-bugs at intevation.de
Subject: d.path documentation should mention how it gets the from and to
points
Date: Fri, 03 Dec 2004 09:41:56 +0800
Message-ID: <87acswupi3.fsf at jidanni.org>
MIME-Version: 1.0
Content-Type: text/plain; charset=us-ascii
X-Spam-Status: No, hits=-4.9 tagged_above=-999.0 required=3.0 tests=BAYES_00
X-Spam-Level:
-------------------------------------------- Managed by Request Tracker
