[GRASS5] [bug #2759] (grass) d.barscale at= not optional
Request Tracker grass-bugs at intevation.de
Thu Dec 2 23:07:07 EST 2004
this bug's URL: http://intevation.de/rt/webrt?serial_num=2759
$ d.barscale help
say "at=" is optional. However,
$ d.barscale
$ extra characters after close-quote
bad window path name ".pw.f0.frame.optwin.fra.frame.lab1"
invalid command name "0,0"
bad window path name ".pw.f0.frame.optwin.fra.frame.lab3"
Therefore one must add at= if we expect it to work:
$ d.barscale at=0.0,0.0
grass 5.7.0
--- Headers Follow ---
>From jidanni at jidanni.org  Fri Dec  3 05:07:07 2004
Return-Path: <jidanni at jidanni.org>
Delivered-To: grass-bugs at lists.intevation.de
Received: from mail.intevation.de (aktaia [212.95.126.10])
	by lists.intevation.de (Postfix) with ESMTP id 5B6FC102BC0
	for <grass-bugs at lists.intevation.de>; Fri,  3 Dec 2004 05:07:07 +0100 (CET)
Received: from localhost (localhost [127.0.0.1])
	by mail.intevation.de (Postfix) with ESMTP id 0DE6A36CE0
Received: from frodo.hserus.net (frodo.hserus.net [204.74.68.40])
	by mail.intevation.de (Postfix) with ESMTP id A27B136F13
	for <grass-bugs at intevation.de>; Fri,  3 Dec 2004 05:07:05 +0100 (CET)
Received: from [219.69.72.5] (port=33578 helo=jidanni1)
	by frodo.hserus.net with esmtpsa
	(Cipher TLSv1:RC4-SHA:128) (Exim 4.43 #0)
	id 1Ca4il-0000Nf-IY by authid <jidanni> with plain
	for <grass-bugs at intevation.de>; Fri, 03 Dec 2004 09:37:04 +0530
To: grass-bugs at intevation.de
Subject: d.barscale at= not optional
Date: Fri, 03 Dec 2004 10:52:36 +0800
Message-ID: <87wtw0t7nv.fsf at jidanni.org>
MIME-Version: 1.0
Content-Type: text/plain; charset=us-ascii
X-Spam-Status: No, hits=-4.9 tagged_above=-999.0 required=3.0 tests=BAYES_00
X-Spam-Level:
-------------------------------------------- Managed by Request Tracker
