[GRASS5] [bug #2763] (grass) v.in.ascii auto-detection too strict
Request Tracker
grass-bugs at intevation.de
Fri Dec 3 01:15:54 EST 2004
this bug's URL: http://intevation.de/rt/webrt?serial_num=2763
Subject: v.in.ascii auto-detection too strict
Platform: GNU/Linux/i386
grass obtained from: Mirror of Trento site
grass binary for platform: Compiled from Sources
GRASS Version: 5.7-cvs_nov04
when using v.in.ascii it automatically decides column type, even if you
specify with 'columns=' e.g.:
columns='x double precision, y double precision, cat int, name varchar(10)'
problem I am having:
I have an input column with data like:
001
002
003
004
005
etc.
I want to load that as a string column, not an int column (even though
they are all numbers). I use 'id_num varchar(3)' but it gives an error
that column type does not match input data type. :(
problem two:
I want to input "nan" into a double precision column, it complains
"column foo defined as double has string values"
'nan' and 'inf' are valid IEEE float/double values;
scanf "%f" reads them, etc.
thanks,
Hamish
-------------------------------------------- Managed by Request Tracker
