[GRASS5] OVERWRITE
Radim Blazek
blazek at itc.it
Fri Dec 3 06:14:47 EST 2004
Glynn Clements wrote:
> Radim Blazek wrote:
>>New GRASS users are usually surprised that most GRASS modules silently
>>or with warning overwrite existing maps. Most normal users
>>however like this feature (AFAIK).
>>Some modules have -o (overwrite) option ( e.g. r.composite, g.copy ).
>>For vector maps it is possible to set OVERWRITE variable to 0
>>to disable overwriting but default (if not set) is 1 (overwrite).
>>My suggestion is:
>>1) use OVERWRITE GRASS variable also in G_open_cell_new,
>> if OVERWRITE=0 and raster exists G_open_cell_new will call
>> G_fatal_error (?, not sure)
>>2) change OVERWRITE default value to 0 (don't overwrite)
>>3) Add a new function G_force_overwrite which can force
>> overwriting even if OVERWRITE=0. Modules with -o flag can use
>> if ( flag_o->answer )
>> G_force_overwrite();
>> before calling G_open_cell_new
> Arguably, the check should be done in G_parser() rather than
> G_open_cell_new() etc. I.e. if the gisprompt field contains "new",
> G_parser() would generate an error if the map/file already exists.
> The reason being that a module could spend a long time processing
> before it opens the output file.
In G_parser() it is impossible to use overwrite flag.
> OTOH, such modules could just be re-written to open the output file
> earlier.
> It isn't strictly necessary to provide an "overwrite" option; the user
> can always run g.remove first.
Yes, but it is convenient. For now g.remove occasionally we can add -o
to modules.
Radim
