[GRASS5] [bug #2776] (grass) d.text when interactive should say
where to enter text
Hamish
hamish_nospam at yahoo.com
Sun Dec 5 02:25:13 EST 2004
> this bug's URL: http://intevation.de/rt/webrt?serial_num=2776
> When we do
> $ d.text
> there is no comment seen in the "wish" window telling us to return to
> the terminal window and enter text.
true. try "echo `g.version` | d.text"
from the help page:
"DESCRIPTION
d.text draws text in the active display frame on the graphics
monitor. Text can be provided through standard input or redirected
from a file (using the UNIX redirection mechanism)."
Yes, a text= option like d.text.freetype is missing.
Perhaps change the module's description until that is done?
I've been meaning to do further cleanups & sync'ing between d.text and
d.text.freetype for a while. Also merge in mouse placement from
d.barscale. It's not a high priority for me though.
> P.S., and when we do go there, we see
> bad window path name ".pw.f0.frame.optwin.fra.frame.lab4"
fixed after 5.7.0.
Hamish
