[GRASS5] 5.7.1
Markus Neteler
neteler at itc.it
Sun Dec 5 09:56:24 EST 2004
Helena,
I just made a test with lidaratm2.txt.gz from
http://mpa.itc.it/grasstutor/data_menu2nd.phtml
wc -l lidaratm2.txt
1158424 lidaratm2.txt
(-> 1.1 Mio points)
cat lidaratm2.txt | time v.in.ascii -z out=mypoints zcol=3 catcol=0 fs=',' columns='x double, y double, z double'
97.05 user
7.50 system
1:52.08 elapsed
0 swaps <--- 750MB RAM
v.info mypoints
| Number of points: 1158424 Number of areas: 0 |
| Number of lines: 0 Number of islands: 0 |
| Number of boundaries: 0 Number of faces: 0 |
| Number of centroids: 0 Number of kernels: 0 |
| Map is 3D: 1 |
| Number of dblinks: 0 |
| Projection: Längen- und Breitengrad (zone 0) |
| N: 35.969 S: 35.950 |
| E: -75.621 W: -75.640 |
| B: -1.937 T: 200.935
cat /proc/cpuinfo |grep MHz
cpu MHz : 2533.639
It's acceptable (since you have to do it one time only).
Did you try
s.out.ascii file | v.in.ascii ... ?
Markus
