[GRASS5] NVIZ updates
Helena
hmitaso at unity.ncsu.edu
Sun Dec 5 20:23:14 EST 2004
I have added 2 modfications from Tomas to nviz volume support:
1. Default polygon resolution for drawing isosurfaces is now a smaller number
(higher resolution) to avoid situation when nothing is drawn.
2. Load state/Save state was added for volume objects.
Bob, after the nviz startup has changed, Load state/Save state does not work
- it gives an Error: can't read env(GISDBASE)
Can this be fixed before the release or should I file a bug report?
Let me know if there are any problems with the new additions,
Helena
