[GRASS5] [bug #2796] (grass) d.vect: only one line thickness
Mon Dec 6 18:39:47 EST 2004
> this bug's URL: http://intevation.de/rt/webrt?serial_num=2796
> d.vect documentation goes on and on about colors, but doesn't talk a
> bit about pen thickness. How is one to distinguish big and little
> roads on a black and white printer?
ps.map is much better for printed hard copies.
  (& setting vector line width works there)
If you must set line width with d.vect, as a work-around use v.buffer.
maybe a nice option for someone to add.
Hamish
