[GRASS5] [bug #2787] (grass) d.vect:
guest user via RT grass-bugs at intevation.de
Tue Dec 7 10:04:36 EST 2004
> If we do
> $ d.vect
> we see the "shape" button is not depressed. But it should be, as it is
> a default when one hits "run".
I guess that this problem appears in all modules having flags.
Would probably require a modification in gui.tcl
Markus
-------------------------------------------- Managed by Request Tracker
