[GRASS5] [bug #2802] (grass) v.to.points type= etc. documentation
Request Tracker
grass-bugs at intevation.de
Tue Dec 7 18:00:00 EST 2004
this bug's URL: http://intevation.de/rt/webrt?serial_num=2802
$ v.to.points help
-i Interpolate points between line vertices.
dmax Maximum distance between points.
default: 100
Mention what happens if we hit dmax and still haven't hit a vertex --
will it Interpolate anyway? And if so, then when does -i come into
play/needed? Don't tell me the answer, instead add it to the man page.
-t Do not create attribute table.
I wish every man page would say if they create attribute tables or
not. At least on this one we get a clue.
DESCRIPTION
v.to.points creates points along input lines.
Parameters:
type Select type: point, line, boundary, centroid or area
options: point,line,boundary,centroid,area
default: point,line,boundary,centroid
Does e.g., "point" make sense? If so, mention the effects of adding it
etc. For all we can tell/guess, type= could be referring to the output
file even.
--- Headers Follow ---
>From jidanni at jidanni.org Wed Dec 8 00:00:00 2004
Return-Path: <jidanni at jidanni.org>
Delivered-To: grass-bugs at lists.intevation.de
Received: from mail.intevation.de (aktaia [212.95.126.10])
by lists.intevation.de (Postfix) with ESMTP id 82440102C3E
for <grass-bugs at lists.intevation.de>; Wed, 8 Dec 2004 00:00:00 +0100 (CET)
Received: from localhost (localhost [127.0.0.1])
by mail.intevation.de (Postfix) with ESMTP id 4D6F736CE0
Received: from frodo.hserus.net (frodo.hserus.net [204.74.68.40])
by mail.intevation.de (Postfix) with ESMTP id AE2DB36CD8
for <grass-bugs at intevation.de>; Tue, 7 Dec 2004 23:59:59 +0100 (CET)
Received: from [219.69.72.127] (port=32828 helo=jidanni1)
by frodo.hserus.net with esmtpsa
(Cipher TLSv1:RC4-SHA:128) (Exim 4.43 #0)
id 1CboJI-000O2w-HP by authid <jidanni> with plain
for <grass-bugs at intevation.de>; Wed, 08 Dec 2004 04:29:57 +0530
To: grass-bugs at intevation.de
Subject: v.to.points type= etc. documentation
Date: Wed, 08 Dec 2004 02:57:52 +0800
Message-ID: <87pt1mrl5b.fsf at jidanni.org>
MIME-Version: 1.0
Content-Type: text/plain; charset=us-ascii
X-Spam-Status: No, hits=-4.5 tagged_above=-999.0 required=3.0 tests=BAYES_00,
DATE_IN_PAST_03_06
X-Spam-Level:
-------------------------------------------- Managed by Request Tracker
