[GRASS5] [bug #2811] (grass) display/drivers/PNG/description.html default GRASS_PNG_COMPRESSION
Markus Neteler via RT grass-bugs at intevation.de
Wed Dec 8 08:33:27 EST 2004
Here related details:
cd grass57/display/drivers/PNG/
grep GRASS_PNG_COMPRESSION *
description.html:  <LI><B>GRASS_PNG_COMPRESSION=[0|1|9]</B><BR>
write.c:        str = getenv("GRASS_PNG_COMPRESSION");
grep PNG_COMPRESSION_TYPE_DEFAULT *
write.c:                PNG_COMPRESSION_TYPE_DEFAULT,
grep PNG_COMPRESSION_TYPE_DEFAULT /usr/include/png.h
#define PNG_COMPRESSION_TYPE_DEFAULT PNG_COMPRESSION_TYPE_BASE
grep PNG_COMPRESSION_TYPE_BASE /usr/include/png.h
   png_byte compression_type; /* must be PNG_COMPRESSION_TYPE_BASE (IHDR) */
#define PNG_COMPRESSION_TYPE_BASE 0 /* Deflate method 8, 32K window */
... still no idea what to add to the HTML page.
Markus
-------------------------------------------- Managed by Request Tracker
