[GRASS5] Re: [bug #2767] (grass) r.stats bug (due to recent
G_store() fix?)
Paul Kelly
paul-grass at stjohnspoint.co.uk
Wed Dec 8 15:51:04 EST 2004
Hello Thierry
On Tue, 7 Dec 2004 tlaronde at polynum.com wrote:
> Hello,
> I haven't look at the code you are trying to fix (I have some other
> stuff ;-), but here are some tips :
Snip explanation of why my suggested fix was completely wrong
> So a correct sequence is :
> title = (char *) malloc(expected_size_of_string_plus_trailing_null);
> *title = '\0'; /* default to empty if intitle not set */
The first line here is more or less what G_store() does. But the recent
change added
if ( s == NULL ) return NULL ;
to G_store.
Perhaps (going by what you suggest above) it should look more like:
char *G_store (char *s)
char *buf;
if ( s == NULL )
*buf = '\0';
else
buf = G_malloc (strlen(s) + 1);
strcpy (buf, s);
return buf;
so you are returning a pointer to an empty string rather than returning a
NULL pointer. But I am still not very hopeful.
The funny thing is I am unable to reproduce this bug so cannot test.
Running 'r.stats -anC fields' in Spearfish with yesterday's 5.7 CVS on IRIX
produces normal-looking output.
Paul
