[GRASS5] [bug #2817] (grass) v.to.db: say what "Database connection not defined for field <1>" means
Request Tracker grass-bugs at intevation.de
Wed Dec 8 18:15:36 EST 2004
this bug's URL: http://intevation.de/rt/webrt?serial_num=2817
In v.to.db/description.html why don't you add:
If you get
  ERROR: Database connection not defined for field <1>
then you should do [...........]
--- Headers Follow ---
>From jidanni at jidanni.org  Thu Dec  9 00:15:35 2004
Return-Path: <jidanni at jidanni.org>
Delivered-To: grass-bugs at lists.intevation.de
Received: from mail.intevation.de (aktaia [212.95.126.10])
	by lists.intevation.de (Postfix) with ESMTP id D37A5102C35
	for <grass-bugs at lists.intevation.de>; Thu,  9 Dec 2004 00:15:35 +0100 (CET)
Received: from localhost (localhost [127.0.0.1])
	by mail.intevation.de (Postfix) with ESMTP id A98F036CE0
Received: from frodo.hserus.net (frodo.hserus.net [204.74.68.40])
	by mail.intevation.de (Postfix) with ESMTP id B3C9636CD8
	for <grass-bugs at intevation.de>; Thu,  9 Dec 2004 00:15:34 +0100 (CET)
Received: from [219.69.72.86] (port=32784 helo=jidanni1)
	by frodo.hserus.net with esmtpsa
	(Cipher TLSv1:RC4-SHA:128) (Exim 4.43 #0)
	id 1CcB1w-0003gK-Pg by authid <jidanni> with plain
	for <grass-bugs at intevation.de>; Thu, 09 Dec 2004 04:45:33 +0530
To: grass-bugs at intevation.de
Subject: v.to.db: say what "Database connection not defined for field <1>"
 means
Date: Thu, 09 Dec 2004 06:19:05 +0800
Message-ID: <87is7cxwkm.fsf at jidanni.org>
MIME-Version: 1.0
Content-Type: text/plain; charset=us-ascii
X-Spam-Status: No, hits=-4.9 tagged_above=-999.0 required=3.0 tests=BAYES_00
X-Spam-Level:
-------------------------------------------- Managed by Request Tracker
