[GRASS5] [bug #2829] (grass) v.to.db: remove an option and am suddenly out of range
Request Tracker
grass-bugs at intevation.de
Thu Dec 9 00:47:56 EST 2004
this bug's URL: http://intevation.de/rt/webrt?serial_num=2829
I remove an option and am suddenly out of range, 5.7.0:
$ v.to.db -p map=largeCat opt=cat,area,length,count,coor
63 categories read from map
0 records selected from table
0 categories read from map exist in selection from table
0 categories read from map don't exist in selection from table
0 records updated/inserted
0 update/insert errors
$ v.to.db -p map=largeCat opt=cat,length,count,coor
Error: value <cat,length,count,coor> out of range for parameter <option>
Legal range: cat,area,length,count,coor,query
--- Headers Follow ---
>From jidanni at jidanni.org Thu Dec 9 06:47:55 2004
Return-Path: <jidanni at jidanni.org>
Delivered-To: grass-bugs at lists.intevation.de
Received: from mail.intevation.de (aktaia [212.95.126.10])
by lists.intevation.de (Postfix) with ESMTP id BF22010016B
for <grass-bugs at lists.intevation.de>; Thu, 9 Dec 2004 06:47:55 +0100 (CET)
Received: from localhost (localhost [127.0.0.1])
by mail.intevation.de (Postfix) with ESMTP id 654FD36DE2
for <grass-bugs at lists.intevation.de>; Thu, 9 Dec 2004 06:47:52 +0100 (CET)
Received: from frodo.hserus.net (frodo.hserus.net [204.74.68.40])
by mail.intevation.de (Postfix) with ESMTP id 12C8436CE0
for <grass-bugs at intevation.de>; Thu, 9 Dec 2004 06:47:51 +0100 (CET)
Received: from [219.69.72.86] (port=33306 helo=jidanni1)
by frodo.hserus.net with esmtpsa
(Cipher TLSv1:RC4-SHA:128) (Exim 4.43 #0)
id 1CcH9W-0006Ht-6l by authid <jidanni> with plain
for <grass-bugs at intevation.de>; Thu, 09 Dec 2004 11:17:50 +0530
To: grass-bugs at intevation.de
Subject: v.to.db: remove an option and am suddenly out of range
Date: Thu, 09 Dec 2004 10:14:15 +0800
Message-ID: <87y8g85ibs.fsf at jidanni.org>
MIME-Version: 1.0
Content-Type: text/plain; charset=us-ascii
X-Spam-Status: No, hits=-4.4 tagged_above=-999.0 required=3.0 tests=BAYES_00,
DATE_IN_PAST_03_06, HTML_MESSAGE
X-Spam-Level:
-------------------------------------------- Managed by Request Tracker
