[GRASS5] [bug #2815] (grass) d.vect help: where=string looks better
Markus Neteler
neteler at itc.it
Thu Dec 9 09:11:42 EST 2004
On Thu, Dec 09, 2004 at 12:14:32AM +0100, Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=2815
> $ d.vect help
> Usage:
> [field=value] [cats=name] [where=name] [color=name] [fcolor=name]
> where=name?
> where=string looks better.
This would require a change in
lib/gis/parser.c
(G_OPT_WHERE)
Not sure that it is trivial, probably all 'name' above would get
changed to 'string' then.
Desired?
Markus
