[GRASS5] Re: s.in.ascii problem
Hamish
hamish_nospam at yahoo.com
Fri Dec 10 02:27:42 EST 2004
> > I can not import any ascii file with string characters using
> > s.in.ascii for GRASS 5.3. It gives a 'segmentation fault. core dump'
> > error.
> > I would like to ask if you have fixed the problem. Thank you very
> > much.
make sure all text strings are "quoted".
if it thinks the number of input column changed it has problems.
(e.g. by a space)
Hamish
