[GRASS5] [bug #2833] (grass) db.execute: \n not a separator
Radim Blazek
blazek at itc.it
Fri Dec 10 03:53:31 EST 2004
Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=2833
> Had to add the \;. Newline wasn't good enough as a separator:
> for c in x y; do echo ALTER TABLE $O ADD COLUMN $c double\;;done|db.execute
Correct observation, separator is ';'.
Radim
