[GRASS5] [bug #2767] (grass) r.stats bug (due to recent G_store() fix?)
Markus Neteler via RT grass-bugs at intevation.de
Fri Dec 10 04:41:39 EST 2004
Message of the day:
r.stats -anC fields,elevation.10m
r.stats:  100%
There was a local leftover of my debugging tests in r.stats.
Of course nobody was able to reproduce it (probably only *after*
the G_store() change revert).
Summary:
- G_store() is as it was before
- r.stats is as it was and works
- probably work to do in db.login
I'll close the bug report now.
Thanks for your patience.
Markus
-------------------------------------------- Managed by Request Tracker
