[GRASS5] Re: [GRASS-CVS] glynn: grass51 configure,1.73,1.74 configure.in,1.63,1.64
Paul Kelly paul-grass at stjohnspoint.co.uk
Fri Dec 10 06:38:21 EST 2004
On Fri, 10 Dec 2004, Huidae Cho wrote:
> Hi list,
> I found that AC_CHECK_FUNC(gdal) doesn't work in cygwin.
Doesn't work on IRIX either; I haven't had time to investigate more and
comment to the list. I thought the point of the gdal-config command is
that you can just use the output of it and assume GDAL is installed properly,
without having to test for the libraries in the usual way.
Paul
