[GRASS5] RE: [winGRASS] the " libgrass_gis.dll was not found !" problem
Koukoulas Sotiris
skouk at geo.aegean.gr
Sat Dec 11 20:40:26 EST 2004
>Please check your library dependency of whatever command you run:
>cygcheck /usr/local/grass.../bin/ps.map
>Then it should print libraries that it requires. Try this in and
outside
>grass.
Done that and here are the results (all not found files exist! -see
lib_list attached):
1. Outside grass on the cygwin prompt: -------------------------------
$ cygcheck /usr/local/grass5.7.cvs-i686-pc-cygwin-11_12_2004/bin/ps.map
P:/cygwin/usr/local/grass5.7.cvs-i686-pc-cygwin-11_12_2004/bin/ps.map
P:\cygwin\bin\cygwin1.dll
C:\WINDOWS\system32\ADVAPI32.DLL
C:\WINDOWS\system32\ntdll.dll
C:\WINDOWS\system32\KERNEL32.dll
C:\WINDOWS\system32\RPCRT4.dll
Error: could not find libgrass_I.5.7.cvs.dll
Error: could not find libgrass_gis.5.7.cvs.dll
Error: could not find libgrass_symb.5.7.cvs.dll
Error: could not find libgrass_gproj.5.7.cvs.dll
Error: could not find libgrass_vect.5.7.cvs.dll
2. From grass5.7 prompt: -----------------------------------
GRASS 5.7.cvs:~ > cygcheck /usr/local/grass5.7.cvs-i686-pc-cygwin
P:\cygwin\usr\local\grass5.7.cvs-i686-pc-cygwin-11_12_2004\lib\libgrass_
I.5.7.cvs.dll
vask.5.7.cvs.dll
P:\cygwin\bin\cygncurses-8.dll
gis.5.7.cvs.dll
P:\cygwin\bin\cygz.dll
datetime.5.7.cvs.dll
gmath.5.7.cvs.dll
symb.5.7.cvs.dll
gproj.5.7.cvs.dll
P:\cygwin\bin\cygproj-0.dll
P:\cygwin\usr\local\bin\cyggdal-1.dll
P:\cygwin\bin\cygjasper-1-701-1.dll
P:\cygwin\bin\cygjpeg-62.dll
P:\cygwin\bin\cygpng12.dll
P:\cygwin\bin\pq.dll
P:\cygwin\bin\cygcrypt-0.dll
P:\cygwin\bin\cygcrypto-0.9.7.dll
P:\cygwin\bin\cygssl-0.9.7.dll
P:\cygwin\bin\cygtiff4.dll
gis.dll
I.dll
vect.5.7.cvs.dll
dbmibase.5.7.cvs.dll
dbmiclient.5.7.cvs.dll
linkm.5.7.cvs.dll
rtree.5.7.cvs.dll
dgl.5.7.cvs.dll
dig2.5.7.cvs.dll
GRASS 5.7.cvs:~ >
Type: application/octet-stream
Desc: lib_list
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20041212/9da1c52b/lib_list.obj
