[GRASS5] [bug #2835] (grass) v.net.path may just be a special case of v.net.salesman
Markus Neteler
neteler at itc.it
Sun Dec 12 09:05:49 EST 2004
On Fri, Dec 10, 2004 at 11:10:14PM +0100, Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=2835
> v.net.path may just be a special case of v.net.salesman, (so say so in
> the docs) but who can tell due to the latter's Description being only
> one line long. Same with v.net.steiner. Not everybody has gone to GIS
> college and would mind knowing what they are about. Takes a .pdf to
> learn?
Have a look here:
http://mpa.itc.it/markus/teaching.html
Slides of 4th seminar - vector network analysis (Neteler, 10 Mar 2004, 800kb PDF)
(No need to complain if you don't like it)
[stuff deleted]
> If http://grass.itc.it/grass57/tutorial/network.html is going to be
> the permanent URL for any information about these, note it on the man
> pages. Often we encounter the man page before the web page.
The URL above is not going to be the permanent URL.
Markus
