[GRASS5] latest binary error
Florian Goessmann florian at wallweg39.de
Sun Dec 12 19:06:36 EST 2004
On 12 Dec 2004, at 23:11, Florian Goessmann wrote:
> thanks for that information! that's a bug i haven't had found yet but
> i could reproduce it and will fix it asap.
ok, should be fixed.
@markus: can you upload the patch to cvs? it's a serious error. to fix
it, i slightly changed the behavior of the GSelect window. it has to be
discussed if these changes are OK but i think they are as they're minor
and don't affect it's original functions. it's more an addition to the
GSelect window than an actual change.
the good thing is, it should now be quite straight forward to get the
symbol collections automatically updated when new ones are added.
regards
florian
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20041213/7c66f469/gtcltk.obj
