[GRASS5] WIND/WIND3
Radim Blazek
blazek at itc.it
Mon Dec 13 03:39:15 EST 2004
Hamish wrote:
>>>I want to merge WIND3 into WIND but then GRASS < 5.7 cannot read
>>>WIND which was written in GRASS 5.7. Any idea?
>>It seems that there are no objections.
>>In any case the user can simply modify the WIND file and eliminate
>>the additional lines if s/he wants to go back to an older GRASS
>>release.
> Shall we modify the 5.4 cvs tree so that it will ignore the new lines?
> That way if there is ever a 5.4.1 etc things will be better....
> I expect that we will find one bad bug which might necessitate a 5.4.1
> some day.
It is desirable to fix 5.4 branch. In fact, there is a bug somewhere in
g.region or gis library - if the WIND file is corrupted or contains
unknown items, DEFAULT_WIND is used without warning in both 5.4/5.7.
Radim
