[GRASS5] rst updates
Bob Covill
bcovill at tekmap.ns.ca
Tue Dec 14 15:28:14 EST 2004
Markus / Jaro,
I also had a build problem (RedHat 7.3) with the latest version from CVS.
To get around the problem I moved the structures, etc listed below from
interpf.h into main.c in v.surf.rst/ .
This solved the problem for me and the program seems to run fine. This
is probably not an ideal solution, but hopefully it helps figure out
what is going on.
Bob
Markus Neteler wrote:
> On Tue, Dec 14, 2004 at 08:08:44PM +0100, Jaro Hofierka wrote:
>>>to make it compile, I have applied the following change in CVS:
>>>RCS file: /grassrepository/grass51/lib/rst/interp_float/interpf.h,v
>>>retrieving revision 1.5
>>>diff -u -r1.5 interpf.h
>>>--- interpf.h 14 Dec 2004 04:06:07 -0000 1.5
>>>+++ interpf.h 14 Dec 2004 08:54:17 -0000
>>>@@ -16,13 +16,13 @@
>>> double smooth;
>>>- struct line_pnts *Pnts;
>>>- struct line_cats *Cats2;
>>>- dbDriver *driver2;
>>>- dbString sql2;
>>>- struct Map_info Map2;
>>>- struct field_info *ff;
>>>- int count;
>>>+extern struct line_pnts *Pnts;
>>>+extern struct line_cats *Cats2;
>>>+extern dbDriver *driver2;
>>>+extern dbString sql2;
>>>+extern struct Map_info Map2;
>>>+extern struct field_info *ff;
>>>+extern int count;
>>>Not sure if it's right but now it compiles.
>>Markus,
>>this is not working on my machine and I'm getting a compile error.
>>Maybe I missed something else, I'll try to fix it.
> Jaro,
> probably the
> #define MAIN
> etc games have to be played? Mhhh.
> However, the current CVS compiles on RHEL 3 and Mandrake 10.0 for me.
>>>My suggestion is to use the following CFLAGS to catch such
>>>problems:
>>>export CFLAGS='-g -Wall -Werror-implicit-function-declaration -fno-common'
> In general these flags are useful to find errors.
> Side effect: It seems to somewhat behave like MacOSX then and uncovers
> potential errors (sort of test emulation).
> Maybe my fix was oversimplified, but some modification is needed.
>>>configure ...
>>>make
> Markus
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
