[GRASS5] d.vect: new segfault
Florian Goessmann
florian at wallweg39.de
Wed Dec 15 11:46:10 EST 2004
markus
it seems to me, that gcc 2.95 simple won't accept any declaration after
the first control sequence call, thus doesn't work with my patch of
d.vect.
as debian and osx both work with the changes you applied, i don't have
any non-working platform.
i'm as lost as you, sorry.
regards
florian
PS: how do you get gdb working? when i want to use it, it complains
about not finding debugging flags although i compiled with -g and
-ggdb.
On 15 Dec 2004, at 09:48, Markus Neteler wrote:
> Florian,
> I had to make the following change to d.vect to get
> it compiled on RH7/gcc 2.9x. It complained about the
> position of the declaration.
> Unfortunately d.vect no longer works on RHEL 3... Sigh.
> d.vect help
> Segmentation fault
> GRASS 5.7.cvs:~ > gdb `which d.vect `
> GNU gdb Red Hat Linux (6.1post-1.20040607.17rh)
> (gdb) r help
> Starting program:
> /hardmnt/thuille0/ssi/software/cvsgrass57/dist.i686-pc-linux-gnu/bin/
> d.vect help
> Program received signal SIGSEGV, Segmentation fault.
> 0x00373049 in _int_free () from /lib/tls/libc.so.6
> (gdb) bt
> #0 0x00373049 in _int_free () from /lib/tls/libc.so.6
> #1 0x00373794 in _int_realloc () from /lib/tls/libc.so.6
> #2 0x00372136 in realloc () from /lib/tls/libc.so.6
> #3 0x00279d0b in G_realloc (buf=0x92e86c8, n=412) at alloc.c:87
> #4 0x0804c525 in icon_files () at main.c:83
> #5 0x0804c727 in main (argc=2, argv=0xbfff8014) at main.c:167
> nl main.c | head -110 | tail -3
> 82
> 83 closedir(dir_i);
> 84 closedir(dir);
> I'm lost again...
> Markus
> On Wed, Dec 15, 2004 at 09:37:23AM +0100, grass at intevation.de wrote:
>> Author: markus
>> Update of /grassrepository/grass51/display/d.vect
>> In directory doto:/tmp/cvs-serv20407
>> Modified Files:
>> main.c
>> Log Message:
>> fixed declaration position for gcc < 3.x
>> Index: main.c
>> RCS file: /grassrepository/grass51/display/d.vect/main.c,v
>> retrieving revision 1.45
>> retrieving revision 1.46
>> diff -u -d -r1.45 -r1.46
>> --- main.c 14 Dec 2004 20:43:40 -0000 1.45
>> +++ main.c 15 Dec 2004 08:37:21 -0000 1.46
>> @@ -57,6 +57,10 @@
>> for (;;) { /*loop over each directory in etc/symbols*/
>> struct dirent *di = readdir(dir_i);
>> + int ni = 0;
>> + char *buf = NULL;
>> + char *buf2 = NULL;
>> + char *buf3 = NULL;
>> if (!di)
>> break;
>> @@ -64,10 +68,6 @@
>> if (di->d_name[0] == '.')
>> continue;
>> - int ni = 0;
>> - char *buf = NULL;
>> - char *buf2 = NULL;
>> - char *buf3 = NULL;
>> ni = strlen(di->d_name);
>> buf = G_realloc(buf,(strlen(d->d_name) + ni + 1));
>> buf2 = G_realloc(buf2,strlen(d->d_name));
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
