[GRASS5] d.vect: new segfault
Markus Neteler neteler at itc.it
Fri Dec 17 12:45:23 EST 2004
On Fri, Dec 17, 2004 at 12:18:17PM +0100, Florian Goessmann wrote:
> didn't you get my email yesterday, in which i suggested that?
Only now I have seen that personal mail.
So we agree :-)
Still searching for a VOLUNTEER EXPERT to fix the icon_files()
portability problems...
M
> On 17 Dec 2004, at 12:14, Markus Neteler wrote:
> >Florian,
> >sorry to say, but then we have to revert it (also d.m if needed).
> >d.vect is an essential program and must work on all
> >platforms.
> >To make it working for now, I have commented the
> >line:
> >/*	icon_opt->options     = icon_files();*/
> >in CVS.
> >Please comment/revert d.m accordingly if needed.
> >Maybe Glynn is willing to look at the icon_files() function?
> >Markus
> >On Wed, Dec 15, 2004 at 05:46:10PM +0100, Florian Goessmann wrote:
> >>markus
> >>it seems to me, that gcc 2.95 simple won't accept any declaration
> >>after
> >>the first control sequence call, thus doesn't work with my patch of
> >>d.vect.
> >>as debian and osx both work with the changes you applied, i don't have
> >>any non-working platform.
> >>i'm as lost as you, sorry.
> >>regards
> >>florian
> >>PS: how do you get gdb working? when i want to use it, it complains
> >>about not finding debugging flags although i compiled with -g and
> >>-ggdb.
> >>On 15 Dec 2004, at 09:48, Markus Neteler wrote:
> >>>Florian,
> >>>I had to make the following change to d.vect to get
> >>>it compiled on RH7/gcc 2.9x. It complained about the
> >>>position of the declaration.
> >>>Unfortunately d.vect no longer works on RHEL 3... Sigh.
> >>>d.vect help
> >>>Segmentation fault
> >>>GRASS 5.7.cvs:~ > gdb `which d.vect `
> >>>GNU gdb Red Hat Linux (6.1post-1.20040607.17rh)
> >>>(gdb) r help
> >>>Starting program:
> >>>/hardmnt/thuille0/ssi/software/cvsgrass57/dist.i686-pc-linux-gnu/bin/
> >>>d.vect help
> >>>Program received signal SIGSEGV, Segmentation fault.
> >>>0x00373049 in _int_free () from /lib/tls/libc.so.6
> >>>(gdb) bt
> >>>#0  0x00373049 in _int_free () from /lib/tls/libc.so.6
> >>>#1  0x00373794 in _int_realloc () from /lib/tls/libc.so.6
> >>>#2  0x00372136 in realloc () from /lib/tls/libc.so.6
> >>>#3  0x00279d0b in G_realloc (buf=0x92e86c8, n=412) at alloc.c:87
> >>>#4  0x0804c525 in icon_files () at main.c:83
> >>>#5  0x0804c727 in main (argc=2, argv=0xbfff8014) at main.c:167
> >>>nl main.c | head -110 | tail -3
> >>>   82
> >>>   83          closedir(dir_i);
> >>>   84          closedir(dir);
> >>>I'm lost again...
> >>>Markus
> >>>On Wed, Dec 15, 2004 at 09:37:23AM +0100, grass at intevation.de wrote:
> >>>>Author: markus
> >>>>Update of /grassrepository/grass51/display/d.vect
> >>>>In directory doto:/tmp/cvs-serv20407
> >>>>Modified Files:
> >>>>	main.c
> >>>>Log Message:
> >>>>fixed declaration position for gcc < 3.x
> >>>>Index: main.c
> >>>>RCS file: /grassrepository/grass51/display/d.vect/main.c,v
> >>>>retrieving revision 1.45
> >>>>retrieving revision 1.46
> >>>>diff -u -d -r1.45 -r1.46
> >>>>--- main.c	14 Dec 2004 20:43:40 -0000	1.45
> >>>>+++ main.c	15 Dec 2004 08:37:21 -0000	1.46
> >>>>@@ -57,6 +57,10 @@
> >>>>		for (;;) { /*loop over each directory in etc/symbols*/
> >>>>		  struct dirent *di = readdir(dir_i);
> >>>>+                  int ni = 0;
> >>>>+                  char *buf = NULL;
> >>>>+                  char *buf2 = NULL;
> >>>>+                  char *buf3 = NULL;
> >>>>		  if (!di)
> >>>>			break;
> >>>>@@ -64,10 +68,6 @@
> >>>>		  if (di->d_name[0] == '.')
> >>>>		    continue;
> >>>>-		  int ni = 0;
> >>>>-		  char *buf = NULL;
> >>>>-		  char *buf2 = NULL;
> >>>>-		  char *buf3 = NULL;
> >>>>		  ni = strlen(di->d_name);
> >>>>		  buf = G_realloc(buf,(strlen(d->d_name) + ni + 1));
> >>>>		  buf2 = G_realloc(buf2,strlen(d->d_name));
> >>>_______________________________________________
> >>>grass5 mailing list
> >>>grass5 at grass.itc.it
> >>>http://grass.itc.it/mailman/listinfo/grass5
> >Markus Neteler     <neteler itc it>       http://mpa.itc.it
> >ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
> >MPBA - Predictive Models for Biol. & Environ. Data Analysis
> >Via Sommarive, 18        -       38050 Povo (Trento), Italy
