[GRASS5] [bug #2877] (grass) Insecure tempfile creation
Stephan Holl
sholl at gmx.net
Wed Dec 29 13:58:37 EST 2004
Dear javier,
thanks for pointing out the insecurities.
But the package you refer to is quite old.
Perhaps you do not know the debian-gis-mailinglist, which can be joined
here: http://lists.alioth.debian.org/mailman/listinfo/pkg-grass-general
There are affords to prepare an unofficial GRASS5.7-package, and
actually there is an apt-getable repository available.
Probably you would like to give it a try.
deb http://pkg-grass.alioth.debian.org/archive unstable main contrib non-free
deb-src http://pkg-grass.alioth.debian.org/archive unstable main contrib
non-free
If you would like to send patches for debian, I suggest to create the
patches against this version, if the problems are still in there.
Thanks
Stephan
On Wed, 29 Dec 2004 17:28:52 +0100 (CET) Request Tracker
<grass-bugs at intevation.de> wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=2877
> Subject: Insecure tempfile creation
> Platform: GNU/Linux/i386
> grass obtained from: Trento Italy site
> grass binary for platform: Compiled from Sources
> GRASS Version: 5.7.0
> This is a showstopper bug for Debian. Packages with security bugs
> cannot enter the stable distribution. This is Debian Bug #287651:
> http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=287651
> Received: (at submit) by bugs.debian.org; 29 Dec 2004 11:01:19 +0000
> From jfs at dat.etsit.upm.es Wed Dec 29 03:01:19 2004
> Return-path: <jfs at dat.etsit.upm.es>
> Received: from tornado.dat.etsit.upm.es (dat.etsit.upm.es)
> [138.100.17.73]
> by spohr.debian.org with smtp (Exim 3.35 1 (Debian))
> id 1CjbZu-00028E-00; Wed, 29 Dec 2004 03:01:18 -0800
> Received: (qmail 10639 invoked by uid 1013); 29 Dec 2004 11:01:16
> -0000 Date: Wed, 29 Dec 2004 12:01:16 +0100
> From: Javier =?iso-8859-1?Q?Fern=E1ndez-Sanguino_Pe=F1a?=
> <jfs at computer.org> To: submit at bugs.debian.org
> Subject: grass: Multiple vulnerabilities (symlink attacks) due to
> improper temporary files use in scripts and source code Message-ID:
> <20041229110116.GB7144 at dat.etsit.upm.es> Mime-Version: 1.0
> Content-Type: multipart/signed; micalg=pgp-sha1;
> protocol="application/pgp-signature";
> boundary="VrqPEDrXMn8OVzN4"
> Content-Disposition: inline
> User-Agent: Mutt/1.5.6+20040722i
> Delivered-To: submit at bugs.debian.org
> X-Spam-Checker-Version: SpamAssassin 2.60-bugs.debian.org_2004_03_25
> (1.212-2003-09-23-exp) on spohr.debian.org
> X-Spam-Status: No, hits=-8.0 required=4.0 tests=BAYES_00,HAS_PACKAGE
> autolearn=no version=2.60-bugs.debian.org_2004_03_25
> X-Spam-Level:
> Package: grass
> Version: 5.0.3-5.1
> Priority: grave
> Tags: security sarge sid
> A lot of scripts provided withing Grass are vulnerable to race
> conditions through symlink attacks in temporary files. Many of these
> scripts either create temporary files in an insecure manner (shell
> scripts do not use 'set-e' and 'set -C', for example) or/and are
> easily guessable.
> Some examples include:
> grass-5.0.3/src/scripts/contrib/i.oif/i.oif:
> # save the Stddev for TM bands
> echo "Calculation Standarddeviations for all bands:"
> $GISBASE/etc/i.oif/r.stddev $1 |tail -1 >/tmp/i.oif.stddev
> grass-5.0.3/src/CMD/generic/GISGEN.sh:
> case $# in
> 0)
> tmp1=/tmp/GISGEN1.$$
> tmp2=/tmp/GISGEN2.$$
> tmp3=/tmp/GISGEN3.$$
> rm -f $tmp1
> touch $tmp1
> rm -f $tmp2
> rm -f $tmp3
> echo "a == 1 { print \$0 ; next }" > $tmp3
> echo "\$0 == \"$STEP\" { a = 1; print \$0 }" >> $tmp3
> awk -f $tmp3 $tmp1 > $tmp2
> rm -f $tmp3 $tmp1
> grass-5.0.3/src/mapdev/v.in.arc.poly/script/v.in.arc.poly
> bindir=$GISBASE/etc
> tempfile=/tmp/temp.ply
> echo 'start eliminating double nodes in ' $1
> $bindir/permut $GISDBASE/$LOCATION_NAME/$MAPSET/arc/temp.ply $tempfile
> rm $tempfile
> [Note: permut just opens this output file without further checks:
> ./src/mapdev/v.in.arc.poly/permut/permut.c
> if ((outfile = fopen (out_ply, "w")) == NULL)
> printf ("can't open tempfile %s\n", out_ply);
> exit (1);
> ./src/paint/Drivers/versatec/3236/DRIVER.sh
> TMPDIR1=/tmp/versatec
> TMPDIR2=/tmp/versatec
> RASTERFILE=$TMPDIR1/_paint
> SPRINT="/bin/sprint >&2"
> SPRINT_COMMAND="$SPRINT $RASTERFILE -v -p 3236 -w $TMPDIR2 -x $ZOOM -y
> $ZOOM"
> grass-5.0.3/src/scripts/contrib/i.spectral/i.spectral
> .where -1 |r.what input=$RASTERMAPS > /tmp/spectr.dum1
> cat /tmp/spectr.dum1 | cut -d'|' -f4,5,6,7,8,9,10| tr '|' '\012' >
> /tmp/spectr.dum2
> Now those are just exmaples of the "easily guessable" temporary files
> used. But a lot of scripts make use of the $$ construct (either within
> shell scripts or C code using getpid()) that is not directly guessable
> but can be infered in a system where a given user is running grass
> more or less accurately either:
> - by looking at the /tmp/ directory and detecting when a given
> temporary file is created and symlink the "next one". For example in
> ./src/scripts/contrib/r.plane/r.plane the following tmp files are
> created in succession: /tmp/$$, /tmp/$$dip, /tmp/$$, /tmp/$$ea,
> /tmp/$$, /tmp/$$no,/tmp/$$ (removed and reused several times). So an
> attacker
> - by bulk creating a huge number of temporary files using the current
> PID of the grass program as a base
> Just try a 'grep -r "/tmp/"' on the sources and you'll see what I
> mean.
> I cannot determine, as I don't use grass, wether the scripts there are
> actually used regularly by users. I would suggest however to patch
> those either by:
> a) Safely creating a per user temporary directory and have all scripts
> use that as a location for all of the temporary files if defined. For
> example, in a common startup script do:
> TMPGRASS = `mktemp -dt grass-XXXXXX` || { echo "Cannot create
> temporary directory"; exit 1 ; }
> export TMPGRASS
> and in auxiliary scripts do:
> [ ! -n "TMPGRASS" ] && TMPGRASS=`mktemp -dt grass-XXXXXX` || { echo
> "Cannot create temporary directory"; exit 1 ; }
> tempfile="$TMPGRASS/tempfile"
> b) Changing all shell scripts to use mktemp or tempfile (might
> make those Debian-specific) when setting up temporary files.
> All the C files, however, need to be modified so that they use
> mkstemp(). So, for example, instead of this:
> (in grass-5.0.3/src/imagery/i.ask/popup.c):
> char tempfile1[40], tempfile2[40];
> sprintf (tempfile1, "/tmp/i.ask1.%d", getpid());
> sprintf (tempfile2, "/tmp/i.ask2.%d", getpid());
> it should use this:
> int tempfd1; int tempfd2;
> if ( ( tempfd1 = mkstemp("/tmp/i.ask1.XXXXXX") ) < 0 ) {
> /* Do something if this breaks! */
> if ( ( tempfd2 = mkstemp("/tmp/i.ask2.XXXXXX") ) < 0 ) {
> and pass the filedescriptor (instead of the filename) to functions
> later on. This means that ./src/libes/raster/Panel.c needs to be
> rewritten (or extended to use fd instead of names in its call.
> BTW, what does this mean?
> grass-5.0.3/src/libes/raster/Panel.c
> /* make sure this file can be written by anybody */
> num = umask(0);
> close(creat(name,0666));
> umask(num);
> Doesn't look too safe to me.. What's the panel used for?
> Now, I'm not sure I can provide a patch fixing all of those, but I'm
> willing to provide a full patch (at least for the shell scripts) if
> time permits.
> However, IMHO this makes this software package unsuitable for release.
> Regards
> Javier
> -------------------------------------------- Managed by Request
> Tracker
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
Stephan Holl
Check headers for GnuPG Key!
http://www.gdf-hannover.de
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20041229/9b6a9acd/attachment.bin
