[GRASS5] Re: 5.3 vs 5.7 disparity
Mon Feb 2 00:43:55 EST 2004
> > > > use of DEFAULT_FG_COLOR/DEFAULT_BG_COLOR for G5.7 compliance
> > > 1. Neither XDRIVER nor d.erase use these macros. d.erase could be
> > > changed easily enough,
> > d.erase is now updated, including support for color=R:G:B.
> Should Derase() be changing the driver's colour table?
Well, it isn't ideal, but I don't think it hurts anything. The part of
the table[*] that is modified is off the end of the chart (MAXCOLORS + 1)
..thus ~extending the color table more than "changing" it. If
something unrelated is calling that color number, it would be a bug
anyway..
[*] here I mean the GRASS standard colors' table, not anything a driver
uses.
src/include/colors.h seems extensible; I don't see anything that uses
MAXCOLORS to set the size of a memory array or anything.
That's not to say something funky won't go on after you call
R_reset_color(), I don't really understand the translation to the
drivers' color tables, but by the look of the comments in colors.h
it would be ok -- and it seems to work ok...
NB:
raster/r.out.png/pngfunc.h  redefines it to 256 for no apparent reason.
src.contrib/CERL/SGI/panel/9.6/src/D.apps/cam.c  redefines it to 4096,
then uses that for an alloc().
src.contrib/CERL/SGI/panel/9.6/src/D.apps/ep.c  ditto.
src.contrib/GMSL/g3d/src3d/raster/r3.showdspf.openGL/togif.c  =>
int[256].
but in those four cases MAXCOLORS isn't colors.h's one and should
probably be changed to something else anyway.
I'm happy to entertain better solutions, but AFAICT it works properly
now (including non-X drivers) and isn't evil.
Hamish
