[GRASS5] tcltk to default
Markus Neteler neteler at itc.it
Wed Feb 4 12:51:59 EST 2004
On Wed, Feb 04, 2004 at 12:34:46PM -0500, John Gillette wrote:
> Grass 5.3 snapshot 2004 01 17
> Redhat 7.3 with updates
> I can't out any way to have default graphics be tcltk except to
> manually edit the .grassrc5 file.  It used to default to this after
> first usage, I believe.
> Is there a utility or command to set this in Grass?
> Perhaps this should appear on the tcltk menu under or near
> "Config"?
try
 grass5 -help
 grass57 -help
 -> "  -tcltk or -gui     use Tcl/Tk based graphical user interface"
This might be what you are looking for.
 Markus
