[GRASS5] [5.7] v.digit
Radim Blazek
blazek at itc.it
Mon Feb 9 06:02:35 EST 2004
On Thursday 05 February 2004 09:03, Hamish wrote:
> Hi,
> some requests/feedback for 5.7's v.digit:
> 1) remove vertex:
> when there are duplicates, there needs to be some way to select
> next/previous line. Otherwise it can be impossible to get rid of
> duplicates by hand. GRASS 5.0's v.digit can do this.
> |---------| what I want to get rid of
> --x-----x---------x------> displayed
> |----------------> only line it will select with mouse
This requires more work, see below. BTW, how this can be done in 5.0?
> 2) settings/symbology (colors):
> yellow is very hard to see on the white background.
> Change default highlight color to blue?
> Make no default color the same?
Blues is hard to see on orthophoto (often dark (forest)), cyan?
> 3) settings/symbology (colors):
> Unchecking box for "Node (2 lines)" & then redraw doesn't work.
> It is impossible to track down where area boundaries are open when
> every node is shown! Had to export to GRASS 5.0 to see where the
> problem was.
Yes, this was bug and I have fixed that, will be in cvs soon.
> 4) Is it possible to exit without saving?
> Nice for beginners, as there is no required input= and output=, and
> you don't always remember to make a copy first.
No, each change is immediately written to disk, this is vector library feature.
> 5) XFree86 is using ~45% of the local CPU when v.digit is running.
> ssh uses about another 45% (tunneled X over ssh). Is it stuck in
> some sort of feedback loop? When you click exit, it stops as soon as
> "Registering Lines: nnnnn", seconds before the menu disappears.
The loop is used in R_get_location_*(), that means always, when v.digit
is waiting for input in XDRIVER.
I don't want to spend too much time on v.digit, it was temporary solution,
my plan is to add v.digit functionality to QGIS.
Radim
