[GRASS5] Re: [GRASSLIST:2530] Re: v.in.ogr not building on Linux
Markus Neteler
neteler at itc.it
Tue Feb 10 10:38:11 EST 2004
On Tue, Feb 10, 2004 at 08:52:03AM +0000, Paul Kelly wrote:
> chris at fonnesbeck.org wrote:
> > Forcing v.in.ogr to compile results in the following error:
> > make: ***
> > [/usr/src/grass57_exp_2003_12_06/dist.i686-pc-linux-gnu/etc/bin/cmd/v.in.ogr]
> > Error 1
> Thinking about it again I suppose also you would need to manually edit
> include/config.h and uncomment the line
> /* #define HAVE_OGR */
> But it would be much better to find out what's causing the problem. I
> thought perhaps something has changed recently to introduce a bug but I
> didn't seem to be able to access the CVS server at Intevation yesterday
> to check. Maybe Markus would know if anything has changed.
It's unchanged for some days. I recompiled the entire 5.7 from
scratch today, no problem.
Markus
