[GRASS5] problems with gdal on WinGRASS under Cygwin
Glynn Clements
glynn.clements at virgin.net
Tue Feb 17 22:10:28 EST 2004
Michael Barton wrote:
> I got a copy of libgdall.1.1.dll from Jeff Hamann. My student tried
> putting it into $GISBASE/lib and /usr/local/lib.
> In both cases, running r.in.gdal produced an error saying that libgdal
> could not be found. Do you have any suggestion as to how to get GRASS
> to recognize that GDAL is present?
AFAIK, Windows doesn't have a concept of library directories. DLLs
have to go in the executable search path, the same directory as the
executable, the current directory, or the "windows" or
"windows/system" directories.
Try putting it in $GISBASE/bin or $GISBASE/etc/bin/cmd; failing that,
try the "windows" or "windows/system" directories.
Glynn Clements <glynn.clements at virgin.net>
