[GRASS5] 5.3 shared libraries and other experimental changes
Moritz Lennert
mlennert at club.worldonline.be
Mon Jan 5 09:51:46 EST 2004
Paul Kelly said:
> Hello everyone
> I made some changes to the 5.3 CVS that are quite experimental and will
> probably break some things. However it allows to build the core GRASS
> libraries as shared, which hugely reduces the size of the binary
> distribution.
> Please test it by adding the following option to the configure script:
> --enable-gmake=no
Works perfectly on Debian testing/unstable with following config:
/data/CVS/GRASSCVS/grass/configure --with-gdal --with-readline
--with-tcltk-includes=/usr/include/tcl8.4/
--with-postgres-includes="/usr/include/postgresql/
/usr/include/postgresql/internal/" --with-motif --with-proj
--enable-gmake=no
Very superficial testing has been succesful up to now.
However, when I add
--with-freetype --with-freetype-includes=/usr/include/freetype2
I get the following error in config.log (which I didn't get last time I
compiled):
configure:10927: checking for freetype/freetype.h
configure:10935: gcc -E -I/usr/include/freetype2 conftest.c >/dev/null
2>conftest.out
In file included from configure:10931:
/usr/include/freetype2/freetype/freetype.h:20:2: #error "`ft2build.h'
hasn't been included yet!"
/usr/include/freetype2/freetype/freetype.h:21:2: #error "Please always use
macros to include FreeType header files."
/usr/include/freetype2/freetype/freetype.h:22:2: #error "Example:"
/usr/include/freetype2/freetype/freetype.h:23:2: #error " #include
<ft2build.h>"
/usr/include/freetype2/freetype/freetype.h:24:2: #error " #include
FT_FREETYPE_H"
configure: failed program was:
#line 10930 "configure"
#include "confdefs.h"
#include <freetype/freetype.h>
I use debain package libfreetype6-dev version 2.1.7-1 which installs
ft2build.h in /usr/include/.
Moritz
