[GRASS5] v.select attributes problem in 5.7
Radim Blazek blazek at itc.it
Thu Jan 8 04:34:28 EST 2004
On Wednesday 07 January 2004 21:57, Christopher Fonnesbeck wrote:
> When running v.select on a vector coverage with attributes stored in a
> relational database (MySQL), the new coverage of selected polygons is
> associated with a new table that has as many entries as the original
> table, even though the number of selected polygons is significantly
> smaller. Is this a bug, or is there another way of getting an attribute
> table that contains only the attributes for the selected polygons?
> Running 5.7 on OSX 10.3
More or less bug, I did not have time to write db_copy_table_where()
so db_copy_table is used and all records are written to output.
Radim
