[GRASS5] d.text.freetype enhancement
William K
woklist at charter.net
Fri Jan 16 10:40:37 EST 2004
Hamish -
There is a dev version of freetype 2.1.8 that's been out a while (it's
pretty stable as far as I can tell). Debian might be using that now
(tho I couldn't say, since I'm on a Mac). This is a documented change
in the whole freetype setup as of v2.1.6. I also had to 'fix' the
d.text.freetype build after installing the new freetype. You probably
need to add a conditional thingy in the configure script and
d.text.freetype source to catch this.
On Jan 15, 2004, at 9:51 PM, Hamish wrote:
> b) figure out why the new Debian freetype2 library requires
> #include <ft2build.h>"
> #include FT_FREETYPE_H"
> instead of
> #include <freetype/freetype.h>
> (see ft2build.h header comments)
> not sure how this affects older systems so I'm leaving it as-is.
William Kyngesburye <kyngchaos at charter.net>
http://webpages.charter.net/kyngchaos/
"Those people who most want to rule people are, ipso-facto, those least
suited to do it."
- A rule of the universe, from the HitchHiker's Guide to the Galaxy
