[GRASS5] Re: updated r.terraflow compile error
Laura Toma
ltoma at bowdoin.edu
Tue Jan 20 15:48:14 EST 2004
There should be a variable that tells the gcc version. Anybody knows
how it's called? I could add something like
#if version < 3.2.2
#include <ostream.h>
#else
#include <ostream>
On Tuesday, January 20, 2004, at 05:22 AM, Hamish wrote:
>>>> the updated r.terraflow causes the automated Linux compilation
>>>> of 5.7 to fail:
>>>> It is a Redhat 7 system (grass.itc.it) - on my Mandrake 9.1 box
>>>> it compiles well. Do you have an idea?
>>>> A quick locate tells me
>>>> /usr/include/c++/3.2.2/ostream
>>>> Seems that r.terraflow is no longer compliant with gcc <= 3.2.2?
> Apparently so.
>>> I've got a RH 7.3 computer I can test it on, and both gcc 2.96 & 3.3
>>> on
>>> my debian one. I'll see what I can figure out.
>> Thanks. Here a locate on 'grass.itc.it'
>> /usr/include/php/Zend/zend_istdiostream.h
>> /usr/include/g++-3/iostream
>> /usr/include/g++-3/iostream.h
>> /usr/include/g++-3/ostream.h
> ^^^^^^^^^ and there's the problem.
> gcc 2.96 (g++) includes both a current and backwards compatible version
> of iostream (and others), but it doesn't include a current "ostream".
> So there's only ostream.h on gcc 2.96, and the compile fails. I guess
> we
> are stuck with setting it to <ostream.h> and seeing "depreciated"
> messages.
> fyi Debian/testing with gcc 2.96, 3.2, and 3.3 has these:
> /usr/include/c++/3.2/backward/iostream.h
> /usr/include/c++/3.2/backward/ostream.h
> /usr/include/c++/3.2/iostream
> /usr/include/c++/3.2/ostream
> /usr/include/c++/3.3/backward/iostream.h
> /usr/include/c++/3.3/backward/ostream.h
> /usr/include/c++/3.3/iostream
> /usr/include/c++/3.3/ostream
>> /usr/include/g++-3/stdiostream.h
>> /usr/include/g++-2/iostream
>> /usr/include/g++-2/iostream.h
>> /usr/include/g++-2/ostream.h
>> /usr/include/g++-2/stdiostream.h
>> /usr/include/aspell/app_ostream.hh
>> bash-2.04$ gcc -v
>> Reading specs from /usr/lib/gcc-lib/i386-redhat-linux/2.96/specs
>> gcc version 2.96 20000731 (Red Hat Linux 7.2 2.96-112.7.1)
>> If it is easier, I could also upgrade the compiler on that machine
>> (but what about compatibility then?).
> Better to make the code work for gcc 2.96, which is pretty standard.
> It'll probably break for older versions of the compiler though, what
> can one do? I'd rather not have "#ifdef GCC_3.3"s everywhere..
> regards,
> Hamish
-Laura
