[GRASS5] PostGIS with GRASS 5.7
Stephan Holl
sholl at gmx.net
Fri Jan 23 13:40:03 EST 2004
Dear GRASS-Developers,
while thinking about using GRASS 5.7 as a 'PostGIS-data-editor' I am
facing the problem, that areas are only read as boundaries by UMN
Mapserver.
You know about that, I guess.
But are there some workarounds to display GRASS-modified PostGIS-data
correctly in UMN Mapserver?!
Another question is about the user management with roles, views etc. in
Postgres.
Is it possible to apply this user management of Postgres to the db-user
who is modifying the PostGIS database?
Any suggestion would be highly appreciated.
Thank you
Stephan Holl
Stephan Holl
GnuPG Key-ID: 11946A09
19:27:54 up 4:56, 1 user, load average: 0.00, 0.00, 0.00
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20040123/6b8a1d08/attachment.bin
