[GRASS5] r.in.gdal
Markus Neteler neteler at itc.it
Mon Jan 26 16:46:48 EST 2004
On Mon, Jan 26, 2004 at 01:11:11PM -0600, Tom Parker wrote:
> I tried the 5.3 update with no luck, I'm going to switch to an older gdal
> not the latest from cvs and see if that helps the 5.3 r.in.gdal patch.
Could you post the dataset in question somewhere? Then we could try
to replicate the problem.
Markus
> -----Original Message-----
> From: John Gillette [mailto:JGillette at rfmd.com]
> Sent: Monday, January 26, 2004 11:55 AM
> To: grass-dev; Tom Parker
> Subject: RE: [GRASS5] r.in.gdal
> Don't forget also the optimization trick, if you haven't
> tried it already.
> CFLAGS=-g ./configure ...
> configure grass as normal and then re-compile r.in.gdal.
> (I would assume you can rebuild only r.in.gdal with
> gmake.)
> This has fixed at least 2 other user's r.in.gdal (maybe),
> one of whom was running Redhat 8.0.
> My theory is that for Redhat >7, optimization is breaking
> r.in.gdal.
> Please let us know if you have tried this already or if it works.
> John
> > From: Bernhard Reiter [mailto:bernhard at intevation.de]
> > Sent: Monday, January 26, 2004 11:56 AM
> > To: grass-dev
> > Subject: Re: [GRASS5] r.in.gdal
> > On Mon, Jan 26, 2004 at 10:10:41AM -0600, Tom Parker wrote:
> > > I'm trying to resolve the r.in.gdal segmentation fault
> > mentioned several
> > > times on the mailing list over the past year. The problem
> > shows itself no
> > > matter what type of raster file I try and import.
> > > My sytem is redhat 9 with gdal/proj/grass all built from CVS.
> > > After installing and/or building and installing several
> > versions of both
> > > grass and gdal as binaries or built from source the problem
> > isn't fixed. If
> > > there is a simple fix I'd love to know it or I'd be happy
> > to try and help
> > > fix the problem.
> > Can you build with debugging support and try
> > to see what the traceback says?
> > Check: http://grass.itc.it/grassdevel.html
> > for links to the "debugging" hints
> > Are there any versions you didn't build yourself?
> > 	Bernhard
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
