[GRASS5] Testing Grass 5.3 - v.transform
Michael Barton
michael.barton at asu.edu
Thu Jan 29 00:20:17 EST 2004
Radim
Just wanted to let you know. I tested v.transform by typing in the name
of a binary vector file (the browse button looks in the dig_ascii
instead of dig folder). It worked just fine. Thanks for the tip.
Michael
On Monday, January 19, 2004, at 01:54 AM, Radim Blazek wrote:
> On Friday 16 January 2004 17:13, Michael Barton wrote:
>> As with GRASS 5.7, I've been doing considerable testing of GRASS 5.3.
>> Overall, it is highly stable and works very well. Here are a couple of
>> minor items that perhaps could be fixed before it is released as
>> stable.
>> 1. v.transform does not operate correctly, at least under Mac OSX. It
>> requires an ASCII vector file as input, looks in the dig_ASCII folder,
>> but will not recognize an ASCII vector file unless it is put (manually
>> and incorrectly) into the dig folder. It produces an incomplete output
>> file (header and attributes, but no vectors). This was a problem on an
>> earlier release; I have tried this on the the 12 January CVS snapshot
>> and it is still a problem.
> v.transform was rewritten to read and write vector binary file.
> Radim
____________________
C. Michael Barton, Professor
Department of Anthropology
PO Box 872402
Arizona State University
Tempe, AZ 85287-2402
USA
Phone: 480-965-6262
Fax: 480-965-7671
