[GRASS5] 5.3: hard links vs soft links
Glynn Clements
glynn.clements at virgin.net
Thu Jul 8 03:05:49 EDT 2004
Markus Neteler wrote:
> > > The recent change to soft links seems to cause problems
> > > also in 5.3. I just received a mail from a user who
> > > downloaded the auto-generated CVS-Linux-binaries from the GRASS site.
> > > Obviously the links are not set correctly (example):
> > > /usr/local/grass53/bin/g.gisenv-> /hardmnt/grass0/neteler/grass_cvs_53exp_pserver_latest/grass-build/dist.i686-pc-linux-gnu/etc/front.end
> > Oops. These should be relative links, i.e.:
> > /usr/local/grass53/bin/g.gisenv -> ../etc/front.end
> > Try the attached patch (I don't have time to fix it in CVS right now).
> Currently I have no 5.3 which I can use to try.
> Anyone else who can confirm that the proposed patch is ok?
> Or, we submit it to CVS and see what happens.
I've committed it to CVS.
Glynn Clements <glynn.clements at virgin.net>
