[GRASS5] libgrass++
Sabine Grabner csab7771 at uibk.ac.at
Thu Jul 8 10:32:57 EDT 2004
hello, i try to read a raster (1885 by 1382) with GetValue(..) of
GRASSRaster.h of Grass++ library. it would take more than 30 minutes just to
read one raster! but unfortunately after about 500 rows i get a core dump and
the display has only scaring signs till i booted again.
obviously GetValue() does a lot of Open() and Close() what might make it slow.
also i have to call this method for each pixel instead read data of required
window at once.
what shall i do to speed up this method and is there also a method to write a
grass raster after treating the data?
thank you. sabine
main():
	int n = 5227350;
	int s = 5180225;
	int w = 179000;
	int e = 213550;
	int xres = 25;
	int yres = 25;
	int cols = (int)(e - w) / xres;
	int rows = (int)(n - s) / yres;
	Window::setStandard(cols, rows, w, n, xres, yres);
	string filename = "dem";
	Raster raster = Raster(filename);
Raster::Raster(string filename)
	char* gisdbase = "/home/sabine/diss/grassdata";
	char* location = "oetztal";
	//char* map = filename;
	char* map = "dem";
	GRASSRaster grassraster(gisdbase, location, map);
grassraster.SetWindow(Window::getN(),Window::getS(),Window::getE(),Window::getW(),Window::getYSize(),Window::getXSize());
	grassraster.Open();
	for (int y = 0; y < data.size(); y++)
		for (int x = 0; x < data[y].size(); x++)
			double xx = Window::getW() + x *
Window::getXResolution();
			double yy = Window::getN() - y *
Window::getYResolution();
			grassraster.GetValue(xx, yy, &data[y][x]);
		cout << y << ". row of " << Window::getYSize() << "\n";
	grassraster.Dump();
	grassraster.Close();
