[GRASS5] Raster files suggestion: new directory layout
Hamish
hamish_nospam at yahoo.com
Sun Jul 11 21:58:52 EDT 2004
> > > > - user can easily copy a map into another machine
> > > > (say, for backup reasons or whatever)
> > > For a quick way of copying maps now try: r.out.mat, copy the map file
> > > to a new machine, then use r.in.mat. I guess you could do GeoTIFF or
> > > something else as well, but this is quick and easy. Things like the
> > > cats/, colr/, and hist/ files don't get included (yet).
> > This is exactly missing. When I have to backup or to copy the map
> > to a friend's computer, I need the full copy. Currently the only
> > way is to use 'find' or manual file selection.
> Well writing an import/export module that included all the components of
> the raster would be a lot less trouble than changing the file structure
> IMHO... (and easier to explain to less experienced users how to use it).
This probably needs a bit more debugging, but....
attached: [r.pack] [r.unpack]
Hamish
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20040712/e7cce731/r.obj
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20040712/e7cce731/r-0001.obj
