[GRASS5] Raster lib and CELL files > 2GB
Markus Neteler
neteler at itc.it
Mon Jul 12 17:17:35 EDT 2004
Glynn,
thanks for your comments below! I forgot to submit additional info:
original ERDAS files:
-rwxr-xr-x 1 dassau users 11184610066 2004-07-09 16:25 040706_rgb_juist.ige*
-rwxr-xr-x 1 dassau users 18261 2004-07-09 16:25 040706_rgb_juist.img*
-rwxr-xr-x 1 dassau users 942589967 2004-07-09 16:26 040706_rgb_juist.rrd*
GRASS (certainly useless) and GDAL recompiled with LFS support:
CFLAGS="-D_FILE_OFFSET_BITS=64 -D_LARGE_FILES" ./configure ...
r.in.gdal then imports the ERDAS files without problem:
grassdata/nnw/juist/cell> l juist_dmcnc.1
-rw-r--r-- 1 dassau users 2317620271 2004-07-09 17:06 juist_dmcnc.1
-> this file is larger than 2GB, probably a correct file.
But then d.rast and other reading commands crash:
row 18793
ERROR: error reading compressed map [juist_dmcnc.3] in mapset [juist],
-> does this need the 'long' changes as you suggest?
[ Another more simple option might be to split the file
with GDAL tools and then to import the pieces ... ]
Thanks
Markus
On Mon, Jul 12, 2004 at 10:05:28PM +0100, Glynn Clements wrote:
> Markus Neteler wrote:
> > for a remote sensing project we face the problem to arrive
> > at file sizes > 2GB. I see two options:
> > a) change the CELL file compression from RLE to DEFLATE
> > -> how to do that? I just want to change locally for me
> That's far from simple. The existing low-level raster I/O
> implementation is a total mess; learning how it works may well take
> longer than re-writing it from scratch.
> Compare read_data_fp_compressed() with read_data_compressed() in
> get_row.c, and put_data() with put_fp_data() in put_row.c.
> > b) enable large file support (http://www.suse.de/~aj/linux_lfs.html)
> > -> any functions which need a change?
> Search for all occurrences of "long" in libgis, then figure out which
> ones need to be changed to off_t. AFAICT, most of them are likely to
> be in the following files:
> G.h (row_ptr field)
> closecell.c
> format.c
> get_row.c
> opencell.c
> put_row.c
> > Variant a) sounds somewhat better to me and maybe already solves
> > the problem.
> > Recommendations are welcome.
> c) obtain a system where "long" is 64 bits.
> Glynn Clements <glynn.clements at virgin.net>
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
