[GRASS5] [bug #2537] (grass) aitoff/winkel tripel fails on rasters
Request Tracker
grass-bugs at intevation.de
Wed Jul 14 16:45:32 EDT 2004
this bug's URL: http://intevation.de/rt/webrt?serial_num=2537
Subject: aitoff/winkel tripel fails on rasters
Platform: other
grass obtained from: Trento Italy site
grass binary for platform: Compiled from Sources
GRASS Version: cvs 20040710
When trying to project a raster from geographic (or any other projection) to a Winkel Tripel or Aitoff,
r.proj spews out VERY many
pj_transform() failed
cause: non-convergent inverse meridinal dist
errors, then gives up with:
ERROR: Input map is outside current region
and stops. The region is correct - I use proj (or m.proj2 in grass53) to determine the extents
needed. And it projects vectors (v.proj) just fine.
Problem with both GRASS 5.3 and 5.7, CVS 2004-7-10, Mac OS 10.3.4, GDAL 1.2.1 + PROJ 4.4.8
(also tried 4.4.7).
-------------------------------------------- Managed by Request Tracker
