[GRASS5] [bug #2543] (grass) patches to build on openbsd without tcl/tk
Request Tracker
grass-bugs at intevation.de
Sun Jul 18 09:49:51 EDT 2004
this bug's URL: http://intevation.de/rt/webrt?serial_num=2543
Subject: patches to build on openbsd without tcl/tk
Platform: other
grass binary for platform: Compiled from Sources
GRASS Version: 5.7.0
My platform is: OpenBSD/3.4 i386
configure args were:
--with-gdal=no
--with-tcltk=no
--with-postgres=no
--with-odbc=no
--with-motif=no
--with-opengl=no
+ the path options for (proj png jpeg tiff).
1. because make is BSD make here, and GNU make is installed as gmake, i had to make these changes:
--- Makefile.orig Sun Jul 18 19:22:28 2004
+++ Makefile Sun Jul 18 19:22:38 2004
@@ -29,7 +29,7 @@
# Shell commands
MAKE_DIR_CMD= mkdir -p -m 755
-MAKE= make
+#MAKE= make
INSTALL= cp
--- include/Make/Platform.make.in.orig Sun Jul 18 19:15:29 2004
+++ include/Make/Platform.make.in Sun Jul 18 19:15:40 2004
@@ -27,7 +27,7 @@
LEX = @LEX@
YACC = @YACC@
PERL = @PERL@
-MAKE = make
+#MAKE = make
AR = @AR@
RANLIB = @RANLIB@
MKDIR = mkdir -p
--- vector/v.clean/Makefile.orig Sun Jul 18 23:16:08 2004
+++ vector/v.clean/Makefile Sun Jul 18 23:16:21 2004
@@ -13,4 +13,4 @@
default: cmd ctest
ctest:
- cd test; make
+ cd test && $(MAKE)
2. also there were some assumptions about OGR which caused link errors
--- lib/vector/Vlib/close.c.orig Sun Jul 18 22:46:32 2004
+++ lib/vector/Vlib/close.c Sun Jul 18 22:46:59 2004
@@ -61,8 +61,10 @@
Vect_save_spatial_index ( Map );
Vect_cidx_save ( Map );
+#ifdef HAVE_OGR
if ( Map->format == GV_FORMAT_OGR )
V2_close_ogr ( Map );
+#endif
if ( Map->level == 2 ) {
--- lib/vector/Vlib/open.c.orig Sun Jul 18 22:47:19 2004
+++ lib/vector/Vlib/open.c Sun Jul 18 22:47:53 2004
@@ -211,6 +211,7 @@
level = 1;
+#ifdef HAVE_OGR
/* Open OGR specific support files */
if ( level == 2 && Map->format == GV_FORMAT_OGR ) {
if ( V2_open_old_ogr ( Map ) < 0 ) {
@@ -220,6 +221,7 @@
level = 1;
+#endif
if (level_request == 2 && level < 2) {
sprintf ( errmsg, "Cannot open old vector %s on level %d", Vect_get_fu
ll_name(Map), level_request );
fatal_error (ferror, errmsg);
3. i couldn't figure out how the shared library stuff was figured out. whatever configure detected was just totally broken. so in the end i modified the Shlib.make to use gcc's -shared argument. i don't know how to fix this properly (it is a hard problem. maybe use libtool?)
--- include/Make/Shlib.make.orig Sun Jul 18 20:29:06 2004
+++ include/Make/Shlib.make Sun Jul 18 20:30:18 2004
@@ -5,7 +5,7 @@
LDFLAGS += $(SHLIB_LDFLAGS)
$(SHLIB): $(SHLIB_OBJS)
- $(CC) $(LDFLAGS) $(LD_SEARCH_FLAGS) $(SHLIB_LD) $(EXTRA_LIBDIRS) $(LIBDI
RS) $(TOOLS_LIBDIRS) \
+ $(CC) -shared $(LDFLAGS) $(EXTRA_LIBDIRS) $(LIBDIRS) $(TOOLS_LIBDIRS) \
$(SHLIB_OBJS) $(EXTRA_LIBS) -o $@
shlib: $(SHLIB)
there are other probs with tcl/tk assumptions, but i think i will just install it instead of trying to figure out how to exclude some modules.
cheers
-------------------------------------------- Managed by Request Tracker
