[GRASS5] [bug #2544] (grass) grass libs built with paths to
source tree, not install dir
Paul Kelly
paul-grass at stjohnspoint.co.uk
Sun Jul 18 17:37:50 EDT 2004
On Sun, 18 Jul 2004, Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=2544
> Subject: grass libs built with paths to source tree, not install dir
> Platform: other
> grass obtained from: Trento Italy site
> grass binary for platform: Compiled from Sources
> GRASS Version: CVS 2004-7-17
> (This is the way it seems to work on OS X at least. It may affect other platforms as well.)
> GRASS 5.7 libraries are built with embedded paths pointing to the source tree. Everything that is
> linked to these libs points to the source tree instead of the installed libs. (Not sure if it's an Apple
> thing, but linking to them uses the embedded path/libname instead of where they physically are.)
> This becomes a problem if GDAL is patched to use GRASS 5.7 libs instead of libgrass.
Please see the attached patch as a possible solution (includes some
changes to include/Make/Shlib.make that should hae been made at the same
time as the changhes to SC_CONFIG_CFLAGS last week.
The only reason I haven't applied it to CVS yet is that I remember some
discussion on the mailing list a while ago about the -rpath linker option
and whether it was a good or a bad idea (can't remember which). I don't
want to make things worse but it probably should be applied as soon as
possible (unfortunately I don't have any more time tonight).
> Normally this isn't a big deal - if the source is removed after installation, dyld is smart enough to try
> defined library paths if it can't find libraries in the original location. But, say the source is built
> inside one's home Documents folder (a reasonable location). On Mac OS X, a users' home folder has
> read access for everyone, but the Documents subfolder does not. GRASS runs as the user's ID and
> doesn't have a problem, but MapServer runs as the webserver. Before dyld has a chance to not find
> the source libs so it can try elsewhere, it fails because it can't get past the Documents folder.
> I found some commented lines in configure to use as a starting point to add a few needed darwin
> options to fix this - darwin needs -install_name (at least), and -compatibility_version and
> -current_version (may be optional, don't know). I ended up with:
> SHLIB_LD="cc -dynamiclib -Wl,-flat_namespace,-U,_cuserid -undefined suppress
> -compatibility_version 5.7 -current_version 5.7 -install_name \${LIB_RUNTIME_DIR}/
> lib\${LIB_NAME}\${SHLIB_SUFFIX} \${LDFLAGS}"
> It seems GRASS_SHLIB_LD_EXTRAS isn't used, so I had to put it all in SHLIB_LD. This builds the libs
> with the correct embedded paths (and the patched GDAL, after rebuilding, is happy). It works, but I
> don't know enough to say that this is the right way to do it. I hard-coded the version numbers
> because with the CVS version, the command that creates the LIB_VER var ends up with '5.7.', and the
> version options don't like that trailing '.' (and I don't know enough about sed to fix LIB_VER).
GRASS_SHLIB_LD_EXTRAS should be used now if the attach patch is applied.
About the LIB_VAR variable: the sed construction worked for 5.3 where the
version number was of the form 5.3-cvs. For 5.7 it is 5.7.-cvs or 5.7.cvs.
I don't know if there's a good reason for this or not--perhaps it could be
changed back to the 5.3 version numbering system to make things simpler.
> A side note on the linking options - undefined-suppress disables prebind, so prebind could be
> removed from LDFLAGS. Harmless warnings otherwise, no big deal.
I think -undefined_suppress can probably be removed now as all the
relevant library Makefiles contain the proper EXTRA_LIBS line.
Paul
? Grass.make
? Platform.make
? shlib.diff
Index: Shlib.make
RCS file: /grassrepository/grass51/include/Make/Shlib.make,v
retrieving revision 1.9
diff -u -r1.9 Shlib.make
--- Shlib.make 13 Jul 2004 11:39:30 -0000 1.9
+++ Shlib.make 18 Jul 2004 21:08:23 -0000
@@ -9,7 +9,8 @@
NLS_CFLAGS=$(GETHOSTNAME) $(ZLIBINCPATH) $(PICFLAGS) $(DEFS)
CFLAGS += $(SHLIB_CFLAGS) $(NLS_CFLAGS)
-LDFLAGS += $(SHLIB_LDFLAGS)
+LIB_RUNTIME_DIR = $(ARCH_LIBDIR)
+LDFLAGS += $(GRASS_SHLIB_LD_EXTRAS) $(LD_SEARCH_FLAGS)
$(SHLIB): $(SHLIB_OBJS)
$(SHLIB_LD) -o $@ $(LDFLAGS) $^ $(EXTRA_LIBS)
